tashasdaddy
- Nov 11, 2005
- 51,019
engine, WT model 5.7 GS SN is 4110179640, v-p XS-M outdrive sn4112058557.
problem. replaced tstat with new, now not getting any water out the the transom of outdrive, on muffs. ran great last weekend. 160 degrees. i need ideas. i the outboard guy, not i/o.
another question. i know it has the circulating pump of the block, but does it also have an impeller in the lower, as like a seawater pump. it is an open cooling system, salt water, flushed religiously.
