water flow on 1980 140 Johnson
nickster2213
replaced water pump and housing on motor. Everything installed great, now when running with garden hose, lots of pressure from pee hole also now i see water coming from hole in the lower unit, is that normal? The old pump did not do that,
rothfm
Ensign
Sounds normal. There is a small hole directly in front down low and one on each side of the gearcase, both flow water.
I have a very strong "pee" after a rebuild. Thought something was wrong(do my own rebuilds) and went looking and verifying. Just a good pump with good flow.
Shouldnt be anything to worry about as long as you verify normal operating temps around and on top of the heads.
