searay1977
Thread starter- Joined
- Aug 6, 2006
- 3
New to forum here.
The boat is a 77 Searay with a Mercruiser 165.
Problem is that I have a slight water drip from the heat tube on the exhaust manifold that goes to the choke assembly on the carb. Is this normal?
It does not drip while engine is running but will after engine is shut down. If I remove the tube leading to the carb the drip increases. Any ideas?
