Re: Water circulating problem
Please provide serial number, to better understand the configuration of your motor.
Does the motor physically overheat?
What is your criteria for 'no flow'? No tell-tale visible, or no flow of water out the prop when running on muffs, or?
Hypothesis at this time:
Blocked tell-tale tubing (mudd daubers or other insects love to build nests in there).
Non-functional thermostat or poppet valve (if so equipped).
Installation issues, or missing/malfunctioning components in the water or exhaust circuit.
