scottn83
Thread starter- Joined
- Aug 26, 2011
- 187
Ok i have gotten my bellows and all changed and finally got it started for the first time using muffs. In doing so it started pouring water into the bilge. The water is all at the bottom of the engine the only thing i can see that is wet is the plate near the starter. No water is getting to the top of the engine pulling off the hose that goes through the transom no water. Not sure if the water that was dumping in was warter that was already in the motor from last time it was run. I was thinking the impeller on the out drive. I am still and amateur and not sure if it could be something else.
Any thoughts
another question should water push through the system with the muffs with out the engine running??
Thanks
Any thoughts
Thanks
