WARNING - Little Things Can Cost Big $$$
Solittle
Just got word today that one of my 1987 OMC V4s is toast & will need a remanufactured powerhead ($$$$) @$#%&^!!!!.<br /><br />This was due to salt water injestion at 4,400 rpm. This was caused by a 1/4" water hose comming off of its T fitting. The hose was on the pan at the base of the block and part of the system that routes cooling water to the teltale. When it cane off (@ 4,400 rpm) it sprayed salt water all over the inside of the motor and was sucked into the engine. It caused detonation damage to one cylinder but also caused pitting to the crankshaft both at the rod journals and top & bottom main bearing.<br /><br />I could have avoided this if I had replaced the hoses as part of preventative maintenance and double clamped them on the T fitting. It would have taken 10 minutes & cost maybe $1.00.<br /><br />I also noticed that the deflectors in the cylinder heads were badly swolen and were, I'm sure, restricting the water flow. I'm going to replace them in the other motor and if you have one of these oldies but goodies I suggest that you do the same.<br /><br />I was somewhat surprised at the relative lack of salt water crud in the heads and in the water passages in the block. Fresh water flushing does pay off.
OBJ
Re: WARNING - Little Things Can Cost Big $$$
OUCH!!!! School of hard knocks rings the bell again.<br /><br />Is the block totally wasted?
Solittle
Yep - Some rather severe internal corrosion plus it had been overhauled once before I bought it.
OBJ
Ya' got another shaker ta' keep ya' boatin? Man ya' know, stuff like that just takes a couple minutes. I blew a head gasket on my 90 just cause I didn't take the time to check the power pack wiring. First crank...POW! adios mushcachos.
lastout
obj: you got my curiousity up. what did you have wired wrong on the power pack that caused the POW. little bits of info to keep in the back of my head. thanks, and also i'm sorry to jump into this conversation. like i said, curiousity got the best of me....sorry.
OBJ
The wiring color code on OMC's and Bomby's is real simple. Green grass, Blue skies. Meaning, that if the wire is green, then it means "DOWN" nomatter if it's the TNT or ignition coils on the engine. Blue means "UP". Simple enough. Well....I got the port side pack wired backa*s wards. I got the orange/green wire on the #2 cylinder and the orange/blue wire on the #4 cylinder. Which means that when the #2 cylinder was at the bottom of the stroke, the plug fired. Bad news Duuuuuuude!
lastout
ohhhhhhh, sorry for the mishap, but thankful for the answer. appreciate the info.
miloman
sorry to hear that it always seems to happen over a small item Murphy's law is at work
