Just got word today that one of my 1987 OMC V4s is toast & will need a remanufactured powerhead ($$$$) @$#%&^!!!!.<br /><br />This was due to salt water injestion at 4,400 rpm. This was caused by a 1/4" water hose comming off of its T fitting. The hose was on the pan at the base of the block and part of the system that routes cooling water to the teltale. When it cane off (@ 4,400 rpm) it sprayed salt water all over the inside of the motor and was sucked into the engine. It caused detonation damage to one cylinder but also caused pitting to the crankshaft both at the rod journals and top & bottom main bearing.<br /><br />I could have avoided this if I had replaced the hoses as part of preventative maintenance and double clamped them on the T fitting. It would have taken 10 minutes & cost maybe $1.00.<br /><br />I also noticed that the deflectors in the cylinder heads were badly swolen and were, I'm sure, restricting the water flow. I'm going to replace them in the other motor and if you have one of these oldies but goodies I suggest that you do the same.<br /><br />I was somewhat surprised at the relative lack of salt water crud in the heads and in the water passages in the block. Fresh water flushing does pay off.
