Re: warning horn ???? 19.5 gls 1989
Hello, I'm new to the forums but have the same boat. If you've solved the problem by now then you probably don't need my input but here goes...
We had the same issue with the warning alarm - it's an engine overheat alarm. We have a 70hp VRO that always set the alarm off. It wasn't getting the oil from the oil tank. We took it to a mechanic, switched the motor over to premix, and haven't had an issue since. We also have a 'rude 9.9 kicker that runs on 50/1 premix so now we have both connected to the main tank. It's a lot simpler system - in my opinion.
Again, don't know if that helps but it worked for me.
