fishingdan
Thread starter- Joined
- Feb 12, 2005
- 1,045
1991 4.3LX alpha with check ball style thermostat housing...
I want to confirm that I'm reading the cooling system flow diagram correctly.
Is it true that warm water will only flow from the top of the t-stat housing to the bottom of the exhaust manifolds if/when the t-stat opens?
Cold water should flow through the check-ball t-stat housing outlets to the exhaust elbows at all times. Correct?
Thanks
Thanks
