wired1236
- Apr 28, 2009
- 111
Re: Wakesurfing behind a I/O??
Long post...anyway here are my two cents.
Have you ever dropped something out of your car window when you are moving? I mean dropped, not thrown. It will travel forward at ALMOST the same rate as the car until it hits the ground. The only reason why is looses a little ground on the car is due to the wind resistance pushing the item back. So if the surfer is traveling at the same rate as the boat when they fall, (most likely they are), and they fall forward in relation to the board directly in line with the prop, there is a CHANCE they will hit it.
Now I bet the reson more people don't hit the propo is that there feet kick back against the board and since the board will most likely slip back in relation to the water due to the pressure of the person's feet pushing against the board but as many people have said, why tempt fait with no faith.
