Blizzard79
Thread starter- Joined
- Sep 2, 2017
- 5
I have an 87 Johnson 90hp vro motor with the 3 wire pump on a boat that I just bought that was in storage for many years. I am in the process of restoring it and noticed that when I turn on the ignition switch the buzzer is on constantly. I did some checking and found that if I disconnected the oil tank sensor ground wire the buzzer stopped so I assumed that the oil tank sensor was bad and bought a new one. I hooked up the new one with no oil in the tank and it still buzzes constantly(not intermittent like it should if low on oil) . I unhook the oil tank and it stops. I don't understand why the constant beep since it should be the overheat warning not the oil sensor. I have had the controller apart and nothing seems corroded or rubbed wires, only thing I noticed is that the switch feels a little rough when you turn it. Any ideas how to test this issue? Thanks for any help.
