VRO buzzer constant on with switch on?
Blizzard79
I have an 87 Johnson 90hp vro motor with the 3 wire pump on a boat that I just bought that was in storage for many years. I am in the process of restoring it and noticed that when I turn on the ignition switch the buzzer is on constantly. I did some checking and found that if I disconnected the oil tank sensor ground wire the buzzer stopped so I assumed that the oil tank sensor was bad and bought a new one. I hooked up the new one with no oil in the tank and it still buzzes constantly(not intermittent like it should if low on oil) . I unhook the oil tank and it stops. I don't understand why the constant beep since it should be the overheat warning not the oil sensor. I have had the controller apart and nothing seems corroded or rubbed wires, only thing I noticed is that the switch feels a little rough when you turn it. Any ideas how to test this issue? Thanks for any help.
Blizzard79
I think I found the problem with my oil tank sensor issue. I tried hooking the oil tank sensor back up while tank was still empty and while the switch was on and the buzzer was on constantly I just turned the tank upside down to move the internal float and the buzzer quit. I assume the thing is working right but why does the intermittent buzzer not work like I have read it was supposed to do with low oil not the constant buzzing I am getting? My old sensor was obviously bad because it would buzz with a full tank of oil so I have that problem fixed but don't understand why buzzer not doing the right thing for warning?
Joe Reeves
The oil tank..... When the oil level drops to 1/4 tank, on that model, the horn should beep every 20 seconds.
If the horn beeps constantly and steady as soon as you turn the key ON (engine NOT running)..... remove the TAN wire from the horn.... If the horn continues to beep steady and constantly, replace the horn.... if the horn stops sounding as soon as you remove that TAN wire, one of the sensors is shorted OR that TAN wire is grounded somewhere.
NOTE that the TAN wire must be connected to the slide on terminal of the horn that is closest to the built in black ground wire. If not, weird things will happen!
Blizzard79
I checked the buzzer and it shuts off when I disconnect the tan wire. The buzzer is not on when the oil tank sensor is unplugged so the other sensors, wires can't be grounded I believe. The only time the buzzer is on is when the oil tank float is down as soon as I raise the float the buzzer shuts off. What controls the buzzer different combinations( intermittent buzz, all time buzz, etc) ? I also should mention that the new oil tank sensor I bought is a newer replacement one, would it be set up different for the buzzer?
Joe Reeves
The upgrade oil tank wiring setup would be the same... The spacing of the beeping (20 seconds) might be lengthened to the later models (40 seconds).
The difference in the beep spacing (Constant - 20 sec - Every other sec - etc) is built into the sensors.
Joe Reeves
I guess I don't really know what is going on then. Thank you for trying!
What is it that you don't understand?
If it has to do with the oil tank.... that sensor is variable. Having the tank upside down has the float bypassing that 1/4 level mark so that there would be no warning, no beeping.
Blizzard79
What I do not understand is why I don't get the 20 second spaced buzzer for no oil in tank instead of a the constant buzz I am getting with tank empty.
Joe Reeves
Hopefully another member that has encountered that in the past will be able to give you an answer... frankly I don't know as I've never encountered a empty tank in the past.
I could only suggest that oil be put in the tank to close to the 1/4 tank level to see if that has anything to do with the circuit acting properly. I see that in post #1 you installed a new oil sensor assembly with the same result which makes me lean in the "Needs Oil" scenario.
