VP GXI 5.0 Belt tensioner replacement DIY
3putter
Belt tensioner is squeaking so i am going to tackle replacing it this weekend. Just curious if anyone has done it and if so, is it fairly straight forward? looks to just be one bolt, but i realized its under tension....i'm assuming there is a spot to put a ratchet to release the belt tension but havent done it before and not sure. thanks for any tips!
BRICH1260
Easy process. Release the tension and slide off the belt. Bolt new tensioner on and reattach the belt.
