Volvo Wiring questions
PowerAddict
I don't know if anyone can help as they are kind of specific.
I've looked at the manual but its too vague. So, here goes.
1. Okay, my ignition switch wasn't getting power, found out the red power wire on the B (main battery from the main relay on the engine) I am only assuming it gives the fuse block power? Whats the best way to trace this down, because I can't just run a new one if its main power as well.
2. On the starter, the main terminal with battery and alternator, there was another connector on it, with a yellow plastic piece and a terminal. Does my trim power wire go on this?
3. coming from the same loom that goes to the starter, there's a grouping of what looks like 2 black wires. I can't figure out where this one goes. Does it go to power??
Sorry, but these are these issues are keeping me from getting this thing finally done!!
Thanks again!!
Bt Doctur
Re: Volvo Wiring questions
Generic answer
That yellow looking piece might be a 90A fuse for the system power. Without it nothing works, bypass it for testing to see if you have power at the ing. switch.
PowerAddict
hmm, I might have to try to snap a picture of this. Its not in-line with anyting, I can't see it breaking power?
