Volvo Power trim
PJFWH170
I've done some testing following the troubleshooting procedure / schematic provided on this site and everything seems to check out Ok but I still have the same problem. The trim won't move in either direction when I hit the switch on the throttle but the relays click. I can move the foot by directly powering the motor in both directions. My engine is a 3.0GS PEFS. Any guidance would be greatly appreciated.
Don S
Re: Volvo Power trim
What procedures were you following, a link would be helpful.
PJFWH170
I followed the test procedures / schematic you sent to LarryFitz 18 on April 19
Don S
Well, if all of the tests check out, replace both relays. The sockets aren't all corroded are they?
PJFWH170
The sockets look OK. Can you recommend a relay supplier ?
Don S
Scroll back to the top of the page and click on Volvo Penta Parts.
PJFWH170
Replaced both relay's and everything is back to normal.
Thanks
