Volvo Penta Tilt/trim and Tach issue
spktho
I have a 1993 Hydroswift with a Volvo Penta 431b motor and a DP-C drive. The problem that I'm having is that the Tach and the analogue Tilt/Trim gauges fluctuate together--when I lower or raise the trim, the tach gauge moves. Also, the tilt/trim gauge does not work very well and does not work all the time. The tilt/trim gauge will also "freak out" occasionally when nothing is being touched. I checked the voltage at the gauges and all looked good. I checked the gauges' grounds and they showed good continuity.
The "Control Unit" Volvo P/N 857448 has a harness that has wires going to both the tach and the tilt/trim gauge, the light on the control unit will come on and off when the gauges "freak out", and one of the relays will click when the gauges "freak". I researched this part number and the replacement is 873226.
I have not located the tilt/trim sending unit on the drive. Does anyone know where it is located? I have the "Volvo 280 to DP-D" manual, but in the location they show, I can't find on my drive.
My question is, do you think the problem is with the control unit, the sending unit or am I missing something else? Thanks in advance for any help.
coastalcruiser
Re: Volvo Penta Tilt/trim and Tach issue
my trim guage was freaking out, I checked for loose wires on the guages and unplugged all the connections made sure they were clean and seated. Problem solved.
spktho
I will definitely try that before throwing parts at it.
wkb2460
How old is your sending unit?
Sometimes they short out and cause the gauge to jump around.
It will also affect your other gauges.
spktho
As far as I know, it's the original sending unit.
Where can I find the sending unit on a DP-C drive?
Ayuh,... I'd be lookin' at the Grounds for the gauges....
