Hi, I have 1997 four winns 170 with a 4.3gl volvo penta and cobra sx outdrive.(Sn T0916447) Prod No. 3868389. When turning there is significant vibration that worsens with more lock, it is smooth in a straight line and running a flat trim is quieter than trimmed fully down. Gimbal was changed and Uj's greased but this has not made a whole lot of difference. The UJ seemed smooth but I now think I should change them as it is pointing to being worn.
The question is can I use the cheap replacement spider option (385012) in even the sierra type brand and can this be done without removing the assembly from the outdrive. Or, should I really replace the whole shaft with either the Sierra or Volvo original unit (which I think is now 3860842). If a whole new shaft is an upgrade then I will go that way. As a seperate question is there a way to tell what length shift cable I would need for this boat, I am trying to get parts together to minimise time out of the water and assume removal and measurement is the normal way.
All help and advice greatly appreciated.
