volvo penta starting issue
jodymartin
Please help I'm at a loss here!!!!
Boat&motor- 1986 21' bayliner capri-aq225e #cu56837.....
ok the boat ran 2 months ago. i decided i was gonna pull out all the carpet and refinish the inside with no carpet, like i said boat ran the week before i started this project...i completed the project boat would not start.... i read a lot of the threads and started with ignition system....no spark...i replaced the plugs and wires about 3 months ago so i started with the points they were bad so i changed the points and condenser and the coil just to be sure....i set the points with a dwell meter as everyone here said..... 30deg while cranking i read that here somewhere.... i now have spark from the coil wire and from the 2 plug wires i checked.... now the engine turns over trys to start for about 1 to 3 seconds and stops..... it seems like when i turn the key back to the run position it stops...i dont have a kill switch.... so i thought it might be a fuel issue so i changed the filters and have plenty of gas from the line in front of the carb.....so i rebulit the carb in accorance with one of the videos i found hear.....motor still does the same thing.......please help i'll try anything to get thing fixed since the Navy dont pay me enough to have someone else do it.....thanks in advance.....
jodymartin
Re: volvo penta starting issue
how do i get people to see these things??????????
jodymartin
ok if i put a jumper wire from pos post to pos on coil it runs fine????????? so whats the problem?????
dubs283
you have a purple wire not connected somewhere
check the purple wire circuit, you will find it broken/unattached somewhere
jodymartin
i cannot find it... i traced it from coil to resistor to starter to ignition.i do have 6 volts at the pos on coil with key on and about 10 while cranking.... could it be the ignition?????
jodymartin
ok i changed the purple wire from the coil to resistor to the starter and still have same issue will not start without jumper from bat. to coil.......it's has to be something else.....suggestions....
jodymartin
thanks for the help fellas but I figured it out myself.........tach wires were hooked up wrong at the dash.......
