Volvo Penta starter wiring help
Rangerbarrow
Can anyone assist me with the wiring setup on a starter I have a 2003 Volvo penta the bolts go vertical for the starter and mixed up where the wiring goes. There is a main wire from the battery, then a wiring harness that contains a two small wires - one purple the other yellow with a red stripe I believe this comes from the ignition, then two medium wires one is red the other orange.
Engine 5.0GL
4012073220
3B69162
Don S
Re: Volvo Penta starter wiring help
See if this helps.
attachment.php
Rangerbarrow
That is very helpful thank you very much I will give it a try!
Rangerbarrow
That worked thanks engine started right up wife gave me a thumbs up now to fix the tilt trim since it wont go up or down!
Thanks very much!
