Volvo Penta outdrive won't raise or lower
Status
Not open for further replies.
weswall31
My volvo penta 270 outdrive won't lower, it will try to go up but not down When I first checked the wiring with a test light, I had power to the black wire on the tilt motor but not the brown wire. My repair manual stated that it could be the relay switch, so I followed the brown wire to the relay made a drawing of the wire location and color and replaced the relay. My part store cross-referenced the relay, I bought another relay and installed it. Now when I hit the switch both relays just click neither one will try to raise or lower the outdrive. I hooked up jumpers to the motor and the motor works in both up & down direction.
imported_raymond2688
Re: Volvo Penta outdrive won't raise or lower
i had thesame problem first time i had relays hooked wrong second time it was the ground wire check both and if the grounds look good take them apart clean them and shrinkwrap it i have the same drive and had the same problem good luck
Hawkdriver001
Weswall31,
I have had the same problem.
There is a "fuse," which doesn't look look a fuse, mounted generally either on top of your boats motor or on the port side. Follow your main power cable (red wire) off your stern drive trim motor. You should find a "junction" (little plastic gizmo) where the red wire from stern drive motor attaches (probably a 10 mm nut). You should see another red wire attached to the other post at this junction. This wire goes to your main (+ positive) power distribution bar/panel.
The little plastic gizmo where the two red wires meet is a fuse. They crap out frequently. I keep a half dozen on my boat all the times. Takes less than 5 minutes to install a new fuse.
Phil
Status
