Volvo Penta AQ 271A Starter just clicks
udm328is
OK, I have done all the listed items and checked them as well which are listed in the adults only section of this site. I have also made sure all connections are tight, and every time I turn the key I only get rapid clicking. Battery is good and charged and I also attached the charger with the starting option turned on and same deal, fast clicking. I a, guessing I am going to be told to remove the starter and have it tested, but I wanted to check here first and see if anyone had any other recommendations. Thanks in advance...
Eric
Don S
Re: Volvo Penta AQ 271A Starter just clicks
Rapid clicking is either low battery, or poor (loose, corroded) connections, bad cables with loose ends on cables.
Not a bad starter.
Looking at a battery, or it's age, or measuring the voltage with a meter is not how a battery is tested. You must use a load test.
udm328is
Thanks Don,
I will go through all the connections and make sure they are good and clean and if that does not work I will replace them. Thanks for your time,
Eric :cool:
