Volvo penta 350hp or 300hp
sml220ss
Buying a new four wins h230 , is it worth the money to get the 350 hp . dealer says there is not enough difference between the 300 hp. he has a 300 in stock
bajaunderground
depends...what's the money we're talking about? a few hundred or a few thousand?
On a 20', 3,100lb boat the difference is roughly 4mph. Both have max RPMs of 5,800. Both are 5.3L unless you go to the 6.0L? Which gives you an additional .9mph increase.
garbageguy
Buying a new four wins h230 ...
That is great. I think the more hp you can get the better, However, since the dealer has the 300 hp in stock, if he gets the feeling you really want the 350 hp, maybe that's bargaining chip on your side.
sml220ss
top RPM is the same but the 350 has larger props so that should give it a little more top end while the extra horsepower will still get to plane quickly I would think . Our current boat has 270hp and have been kicking myself for not getting the 300 hp . Do not want to make the same mistake , Thanks for you thoughts
alldodge
The old saying, there is no replacement for displacement. HP is great but it takes torque to get you up. No one talks torque much anymore and the numbers are getting harder to find documented.
When I bought my boat there was a test ride, maybe ask for two in order to compare. Most boat sales folks are just like car sales, they will say anything to get you to buy.
Edit: also note there getting some of the extra HP by increasing the RPM
muc
"Retired" Association of Marine Technicians...
To answer this question properly, need to know how you plan to use the boat. And is this a single prop or duo prop?
sml220ss
It is a dual prop,a little water skiing tubing and running down the lake
alldodge
Good point, might be a mute point on the cu in
Here are the option VP motors at the Four Winns site for the H230
  • Volvo Penta? V8-300C/DI/DP 300hp
  • Volvo Penta? V8-300C/DI/SX 300hp
  • Volvo Penta? V8-350C/DI/DP 350hp
  • Volvo Penta? V8-350C/DI/DP EVC 350hp
  • Volvo Penta? V8-380C/DP EVC 380 hp
muc
The 300hp will be ok as long as you can keep weight of passengers and gear below 600-700lbs. If you want to carry more passengers it might be good to pay the $5,000 extra for the 350hp.
If water sports are going to be a big part of your use, it would be a good idea to look at the TS series. The Volvo forward drive makes a huge difference when a boat is used for tow sports.
sml220ss
They are both the 5.3 liter , I read they electronically hold back the hp on the 300. Thanks for the responses
Ayuh,.... Welcome Aboard,..... In All my time here, I've yet to find anybody complain 'bout havin' To Much Horsepower,.....
It usually comes down to the money,....
Of course a year or so later they're here askin' how to Boost their Horsepower,....
four winns 214
Bondo's right.
Boats are very similar to airplanes. A saying in aviation is, "there's no substitute for horsepower."
I have a 21' deckboat with a 5.0L. At light weights its response to throttle is delightful. At heavy weights, it's a bit of a dog until achieving 3,000 rpm.
