DDAADDYY
Thread starter- Joined
- May 23, 2004
- 100
So I just picked up this boat with a Volvo AQ131D 4 cyl. with the 280 SP/MT leg the one that just tilts and doesn't trim. When I jumper the tilt motor to the battery with both leads, ground and power it works fine although the manual says just to use 1 wire to the positive of the battery. The trim button on the control sounds as if it triggers the switch but that's all that happens. Steering fork bushings are gone so I'm changing them but other than that this suckers a keeper in great shape. Any help on this tilt thing would be great. Do I need to change the tilt motor because I need both wires, or am I missing something here. The lift device looks to be in perfect shape and as I said the switch seems to click when I hit the switch at the control. Only other thing is how does the box connect to the controller as I can just remove it and the manual doesn't really show how it connects. I'm sure that's the problem. Thanks in advance for your help guys.
