volvo GI NO START FOR A FEW MINUTES
skyhawk172
I have a 04 crownline 225 br with the volvo 5.7gi and dp. When i first try to start it for the first time it just spins over for about 2 minutes then starts hitting a little then fires up and runs perfect. The rest of the day it starts and runs perfect. When i first try to start it i checked and it is firing and i can here the fuel pump running but i haven't checked fuel pressure which i doubt or injector pulse yet. Any ideas before i get started checking stuff it is gm 350 if that matters thanks
Menard666
Re: volvo GI NO START FOR A FEW MINUTES
If you have spark and you have air then you're only missing one thing.....hook your fuel pump up to clear line and put the other end in a gas can and see if that helps.
