Volvo duoprop
PJWENNING
7B347DE7-45F5-4DED-97AD-A4E4F10262BF.jpegB48E74CF-CEB7-4EBA-A095-0DFEC3FB8777.jpeg884019D5-F210-4A6C-9ABF-48810F715791.jpeg
This year I bought a new to me 2008 cobalt 252 with a Volvo 8.1 GI-J.:.I left lake george this year with a blueing where the two props come together on the shaft.. The props came off fairly easy with a decent amount of grease still left on the shaft and no obvious issues with the shaft itself.. The duoprop had obviously wear on the hub where the blueing occurred and was looking
for any insight as to the cause of the wear and blueing… I’m fairly concerned that this amount of heat still occurred while in 70 degree water.. Thanks
Props are rubbing on each other. Are you missing hardware between the props?
PJWENNING
No idea that’s why I’m asking when I took it aPart I ended up with one forward prop nut one rear prop nut two props .. lol
alldodge
Each prop has a thrust washers on the shaft. Is there 2 washers?
PJWENNING
Not that I know of..The only things I took off is what was previously mentioned.. the forward prop actually started to score in to the Aft prop
PJWENNING
I assume that the props are in bad enough shape that they should be replaced or should this remedy my issues
alldodge
This hould fix the issue. Dont know which one your missing but think its the front
PJWENNING
Do you know if I was to order new Volvo props if those thrust washers came as well?
PJWENNING
PJWENNING
So I got a few part #s and the two prop numbers are 3851466 and 1851476 both are f6 7K don’t know if this helps at all as most diagrams I’ve seen don’t typically have a thrust washer?
alldodge
No expert with VP, but thrust washers don't normally come with any prop
Nashville
Please check the part number that begins with 185… and repost (better, post a picture of that prop with the engraved markings visible). 185… is not correct. This should be an F6 set with straight splines on a DPS-A drive. No thrust washers on this series like the 280/290’s. Please post a picture of both nuts. It’s possible the inner nut is incorrect, a shaft is floating, the hub slipped, one was under torqued or one wickedly over torqued. Cause remains to be determined. Thank you.
PJWENNING
004188E8-F893-47CB-B55E-B9D7684DA58B.jpeg51DB93ED-B32E-4E74-96A5-81B4E39F8ACE.jpeg16A9369B-4A30-477C-8718-84797E64F962.jpeg11BD8B02-CE86-4168-906A-744C58C6A5EE.jpeg6A0D61FB-E52D-4C92-B544-437EDAD9CF0B.jpegEA525E45-8B89-4AB1-8694-CAB8DF8B1690.jpeg
I was able to hopefully get a. Few better pictures of the engraving and heating..The 2nd and 3rd show the ring it’s starting to create the 4th shows the opposite side the others show where it is also creating some sort of friction Finalized by the 2 nuts I took off..Thank you everyone
Nashville
View attachment 350086View attachment 350087View attachment 350088View attachment 350089View attachment 350090View attachment 350091
Thank you. Looks like contact on the face of the front nut (larger of the two props). A few initial matters to look at. (1) The nylon insert seems to have a gap between it and the I.D. based on the new picture of the smaller of the two props. It might be the picture though. So, please inspect. There’s a machined taper, but should be no gap. (2) Since the props are off the drive, grab the inner shaft and move it laterally and then in/out. Do the same with outer shaft. Let us know what you find. There should be near zero movement (a couple thousandths). It’s best to use a dial indicator, but if you don’t have one, do your best and see if there’s gross movement. (3) Look at the drive and see if there’s wear on the housing at the root.
