rfdfirecaptain
Thread starter- Joined
- Aug 17, 2008
- 314
1993 Volvo 7.4 engine with a DP-D outdrive
OK, now that I have the prop cone off I am still following a DP-C manual (becasue it's all I can find) the manual does not give instructions on the outer prop removal.
It appears the prop is on the spline without any attaching bolts or set screws. I've tried using penetrating oil and tapping with a mallet and it will not budge when I try to pull it off the spline.
I've read other forums addressing how to cut the propellar off, but before I do that I would like to give it the old college try to save the propeller first. Otherwise this the cost of this repair is going up even more
Any suggestions?
Any suggestions?
