Volvo AQ131A Exhaust Manifold
qb1er
I read somewhere that if there is less exhaust water expullsion coming out of the outdrive and white smoke coming out, the exhaust manifold is going bad. I have a Volvo Penta AQ131A and have noticed this recently. If I replace exhaust manifold, do the risers need to be replace also? I run in saltwater here in Southwest Florida and it's brutal on my engine. Could the problem just be as simple as the impeller? Also, where can I find an online manual for this motor, 1986 Volvo Penta AQ131A?
captmello
Re: Volvo AQ131A Exhaust Manifold
Welcome!
Salt water eats manifolds. I'm sure you can get them here on iboats or locally. However I don't know if thats your problem.
If you don't know when the impeller was changed last, change it, and do it every two years. Those drive trains require a lot of routine maintenance. Is the motor overheating? Are you reaching up close to 5000rpm at wide open throttle?
