volvo 5.7 GS erratic oil pressure reading
63A
Engine is a 5.7GS in 2000 Monterey 240. Engine runs great- no issues with starting or performance. Engine isn't burning oil. Oil still looks close to new (color) after 10 hours since change. Oil presuure reading is erratic- sometimes pressure drops as engine RPMs increase which seems odd. Max oil pressure reading is 40 with min at 10. Oil pressure does not appear to coincide with engine rpm. Should I try a different sending unit or guage? Is oil sender on Volvo 5.7 same as any other Chevy 350 or do Faria guages require a specific sending unit?
Thanks
jtybt
Re: volvo 5.7 GS erratic oil pressure reading
put in a mechanical gauge.
as with any electrical part that's working erratic, check connections.
mikeneal
Yup 99.99% of tyhe time ther sender is failing and the readings are not accurate.
wca_tim
also, check the wire / fitting that leads to the sending unit. doesn't take much sometimes...
