pine island fred
- Dec 20, 2002
- 1,144
Helping a friend replace the engine in his CHAPARRAL. Crate got dropped off at my house yesterday and I started doing some planning and came up with a few questions.
Seized/ rusted engine coming out is a chevy 305, its laying on the ground, ugly unit. Friend bought a 350 long block with a roller cam. Intend to use the old flywheel and he has purchased a new harmonic balancer. Saw the new balancer tonight and it just has a scribe marking TDC. Figure I can use a set of dividers to mark the 4 or 6 degs. mark we will need for timing, taking the distance off the old balancer which has a decal. Figure this will work if they are the same diameter. Are they?
Next is the cam, it has roller lifters which I have no experience with. Are they solid lifters with a roller. Do they need to be adjusted as with any solid lifter? Finally the fuel pump. Looks like a normal pump with an arm to ride the cam. Friend mentioned something about a push rod to drive the pump. Is there one? Block is so corroded with salt water that it is impossible to tell what is up there on the old block and it is locked up tight so I cant turn it to see if something moves up there. Would appreciate any advice.
Also, are roller cams that great? thanks FRED
