This motor fires up first time every time and idles well even if clicked into gear. Open the throttle and she doesn't rev under load but will peak if run out the water. She stood for a year and picked up dirt from a corroded fuel pick up. Work completed:<br />The tank and fuel line was cleaned and flushed with new fuel.<br />Carbs cleaned.<br />New plugs fitted.<br />New fuel pump fitted.<br />Also tried electrical fuel pump.<br />All electrical connections cleaned and checked.<br />New choke seals fitted.<br />All small rubber pipes between carbs and engine cleaned.<br />Float levels adjusted.<br />Cylinder drop test. All cyl. OK.<br />I have performed most of this work and it has just all been redone by mechanic. He is now battling as well.<br />Any other suggestions / possible solutions?<br />Glenn.
