Voltage after fresh charge?
Mark42
Just charged a 4 year old battery. Its a class 24 1000 amp (800 cca) marine general purpose battery. It is not charged during the summer, the boat takes care of that. During the winter it is on a trickle charger.
This weekend it was charged at "6v high, 12v low" setting after running the power tilt/trim up and down a bit, and doing repeated starting chores. It pulled about 10-12 amps for 15 minutes until dropping down to almost 0 after half an hour, when it was disconnected. Using a multi-meter, the voltage is 12.64. Seems a little low.
Distilled water is always added when needed, and the cells are all full. In fact, as the battery charged, a few cells bubbled enough to spit out some electrolyte. About 2 oz total spilled to the garage floor (best eye ball estimate).
This battery has been performing very well all this past summer, being charged only by the Force outboard.
Just wondering if the post charge voltage seems low for a battery of this age.
Thanks.
trendsetter240
Re: Voltage after fresh charge?
12.6 resting voltage is fine and is what you should expect from a fully charged battery.
Mark42
Thanks. Hopefully, I can get another two years out of this battery.
Just what do you mean "charged 6V low and 12V high"? No 12 volt battery should be charged at a 6 volt rate. Thats for charging 6 volt batteries. If both 6 and 12 volt settings also have high and low charge "rates" then you first select 12 volts (for 12 volt batteries) and then the Hi or Lo rate (which we have no idea what those charge rates are). A 12 volt battery is a "battery of cells" or more specifically, six 2.1 volt cells. 6 x 2.1 = 12.6 which is the static voltage of the battery.
Lastly, keep running the battery down to "0" is a good way to destroy it. The battery should never be that deeply discharged.
jhebert
Ensign
...the voltage is 12.64
The terminal voltage of a lead-acid battery will vary a bit with temperature. The accuracy of the voltmeter is also important. A "full charge" should be between 12.6 to 12.8-volts.
You may want to leave the battery on a float charge for a day or so to bring it to full charge.
Mark42
I use an commercial battery charger. It has setting for 6v low, 6v high/12v low, 12 v high and "start" (600 amp starting cycle). Those are the only choices. I use the 6v high/12 v low to do a slow charge on a 12 volt battery as per the instructions printed on the side of the unit. It displays the amperage the battery is drawing. Been working fine for 15 years or more.
BTW, nowhere did I say the battery was being run down to zero. Where did you get that idea?
Quote: This weekend it was charged at "6v high, 12v low" setting after running the power tilt/trim up and down a bit, and doing repeated starting chores. It pulled about 10-12 amps for 15 minutes until dropping down to almost 0 after half an hour, when it was disconnected. Using a multi-meter, the voltage is 12.64. Seems a little low.
Your statement about running the trim/tilt and pulling 10 - 12 amps led me to mistakenly assume the "almost 0" meant battery voltage was almost zero.
I still cannot believe the charger instructions tell you to charge a 12 volt battery on a 6 volt setting (high or low).
Rick.
We have a charger at our shop that has 6Volt high/12 v. low as one setting as well. I have always wondered about it. It also has settings for 12v. medium as well as high. The amp gauge has not been operational for a number of years. Rick.
Mark42
.....I still cannot believe the charger instructions tell you to charge a 12 volt battery on a 6 volt setting (high or low).
This is a pretty common setting on big chargers. I think its because current/amperage is more important than the voltage it provides. For example, a small bench top charger I have is putting out 18 volts on the 12 volt setting, and about 10 on the 6 v setting.
I have a small "trickle charger" that when tested was putting out about 20 volts.
I don't know why chargers are set up this way, but that is how it is with the chargers I own.
If you are measuring a charger open circuit they will all output much higher than they would when connected to a battery. It means nothing. This is why outboards with unregulated charging systems tend to boil the water out of a battery at high speeds. In those applications charging system voltage is routinely 16 - 17 volts or more.
It is interesting that the battery manufacturers do not mention charging 12 volt batteries at 6 volts (high or low current) in their own charging discussions. I would really be interested in being pointed to some documentation supporting this process (or at least posting the make and model of the chargers involved).
trendsetter240
Your charger must have an internal component that can detect the battery voltage and adjust as required.
Voltage is very important during charging; you cannot charge a 6v battery at 15v and you cannot charge a 12v battery at 10v.
As mentioned in a prior post a 12v battery is 6 x 2.1v cells. In order to charge these cells the voltage must be higher than 12.6v. The battery cells must be brought up to a high enough pressure (voltage) in order to complete the chemical reaction needed to "store" energy.
If you watch the charge profile of a smart charger with a typical lead-acid battery it will do as follows:
1. Bring the battery up to around 15-15.5v until it absorbs less than a certain amount of current (amps). (Bulk charge)
2. Increase amperage and lower voltage to around 14.2-14.4 volts until again the current absorbed by the battery drops to a certain amount. (absorption charge)
3. Reduce amperage and voltage to appx. 13.2v and maintain voltage at that level adjusting current as required. (float charge)
If you charged your 12v battery with that charger and it now holds a steady 12.6v then it must have been putting out sufficient voltage. I agree the switch label sounds misleading but if it were truly 6v the battery could not have been charged.
wire2
Mr. Ohm would tell you that's impossible. I = E/R.
R (battery) is constant, so increasing amperage will require the voltage to be increased.
Mark42 has it right; the charger voltage must be greater than the battery voltage for current to take place. Setting the dial to 6 or 12 v chooses an appropriate current range for each.
Open circuit voltage on a charger means very little, it's just the electronic sensing is not seeing current, so it goes to maximum. And that is dependant on the transformer ratio, rectifier efficiency and if it has a capacitor in the DC circuit.
trendsetter240
Of course you are correct. It should read REDUCE amperage and lower voltage to around 14.2 - 14.4v.
My bad;)
Fed
I'm betting the 6V high/12V low setting delivers 13V or so and relies on the battery's internal resistance to take care of the Amps.
