70hp 87 Johnson sluggish on throttle advance
lighthouscker
Hi all. New to the forum but glad I registered. Seems to be some great information here. My 70hp Johnson boggs down on advance of throttle after no wake speed. Also noted when it finally does get up to speed and then crossing someones wake it will bog down again. Seems to run ok at idle unless idle speed is well advanced. New plugs, new gas, new filter and water seperator. Problem shouldn't be vents on inboard tank as problem followed with using an external 6 gal. tank. Ideas? Comments? Suggestions?
Thanks
Mike
tashasdaddy
Re: 70hp 87 Johnson sluggish on throttle advance
have you check compression? when were the carbs last done? link & sinc? did you check spark on all 3?
lighthouscker
Thanks for the input. Carbs were just done in 0ct. 07 spark is good on all 3 checked with inline meter. Sorry but I don't understand what exactly linc and sync is? All input is deeply appreciated.
Thanks
Mike
tashasdaddy
how old is the gas? linc n sinc, is a step by step process, directions in service manual, it coordinates the spark advance , with the carbs, so that the motor runs properly. if the fuel advances before the spark, the motor starts to flood before the spark can catch up. it also could be that you have some carb jets starting to clog.
lighthouscker
Gas was put in in april 08 but have also used an external 6 gal tank of fresh gas last weekend. Same problem with that fuel. Thanks for the info about the jets that might be a good place to start since it did run ok for abit under full throttle until I crossed someones wake and maybe the vibration disturbed some material?
Thanks again
Mike
lighthouscker
Ok Tashasdaddy. That was some really quick supplied info which is deepely appreciated. Guess that means my F-day wknd will be spent cleaning jets :rolleyes:
Thanks again
Mike
tashasdaddy
besure to note which carb is in the middle, and keep the parts of each carb separate. the middle carb is a little different.
