Sup fella's I've wrote in before 'bout the same problem. The guy at the shop seems to think I,m O.k. but he says the prop is bent a little but not enough to hurt anything. Can that be?? Can you run a bent prop shaft at high speeds and not hurt anything even if the bend is less than 1/32 of an inch or less??? This is on a 1984 Evenrude 150 <br />I dont think you can it seems like it would shake the lower unit apart, bust all the seals and stuff. What do ya think? this guy crazy??? or am I lucky??? Thanks, come on snake eyes.....<br /><br />------------------
