V6 oil leak, fixed?
achris
More fish than mountain goat
Previous thread that started over 2 years ago with this problem. Click HERE
After a couple of years of chasing this problem I believe I may have found my problem.
Brief history: Purchased the engine new Nov 2006. In May 2009 (engine hours - 150) it developed an oil leak from the bottom of the timing cover. On removal of the sump I found a crack in the bottom edge of the plastic timing cover. As the engine was out of warranty Mercury Marine wiped their collective hands of me. Not even offering a repair method that would solve the problem. I replaced the timing cover thinking it was just a one off failure. 8 months later the engine leaks oil again. This time I look a lot more closely at the timing cover and sump and notice that the sump was deformed where the cover was cracked. I filed the raised area down and fitted a new oil pan gasket with sealant and hoped for the best. That one lasted just over 12 months, and then started to leak oil again. This time I had had enough and decided to take it back to the dealer for him to sort out. He quoted $3,000, which included 7 hours to fit a new timing cover and sump, and 6 hours to drop the engine back in the boat (it takes me less than 2 hours without breaking sweat!). On inspection the leak appeared to have come because of a lack of sealant, not a cracked cover. So I loaded the gasket with sealant and refitted it all. That was in June 2011. It leaked again 2 months later. I removed the engine (I just whistle now and it jumps out by itself) and found the cover cracked in 2 places, the result of too much sealant putting excess pressure on the unsupported area of the timing cover. I put yet another new timing cover on and was really careful with the sealant and put it all back in the boat.
Bearing in mind that each time I have done this work it has been from underneath the engine while it has been suspended on a chain block.
Took the boat out for a test run, confident that all was well, and it was, for about 20 minutes. Lots of oil coming out! This is getting silly. I pulled the engine, again and this time decided that I would do it differently. I have modified an existing engine stand so I can rotate the engine and work on the sump. See the photo of the ?engine rotisserie?. I didn?t like the idea of 650 lbs of fully assembled engine hanging on 4 bolts in the back of the flywheel housing. I have built a frame that the engine mounts into and it supported at both ends. Spinning the engine over it easy and very comfortable, without the engine just hanging by its back end. I was cutting and welding for about 7 hours to fabricate the frame, and I?m more than happy with the result.
attachment.php
attachment.php
attachment.php
When I took the sump off, this time working from above it, I noticed that the oil pan gasket was sealed perfectly. On very close inspection I have found an area each side of the timing cover that was not being sealed. See red arrows in the photos.
attachment.php
attachment.php
I will be sealing it up and putting back together, this time in such a manner that I can see what I?m doing?. I will keep this thread posted with the result. Hopefully, after 2 years and 4 timing covers?
Cheers, and to all of you out there who own V6s with a plastic timing cover and an oil leak, there is hope!
Chris????
achris
Re: V6 oil leak, fixed?
Just took the boat out for its first run, and all the oil stayed in the engine. :D
Ayuh,.... I sure hope this is the end of this painful journey for ya Chris,...
I know this leak has been beatin' ya up for a Loonnngggg time...;)
Dean Anderson
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Chris????
Chris
I was wondering how your project turned out? Has your leak gone for good? Mine has just started, I have twin 4.3's with 350hrs and they both leak at the base of the plastic crankcase covers.
I want to just use RTV Silicone to try to patch them, they only leak a tea spoon of oil every month or so.
Any suggestions..
Dean
bonzoscott
Hey! Completely unfamiliar with plastic timing covers. Do you suppose fact being plastic is the cause? I've been familiar with several automotive plastic intakes failing and smoking the motor. Is it specifically designed for the plastic cover and can't replace with the steel one?
achris
Hello Dean and :welcome: to iBoats...
Your post raises a few issues. Firstly I'll answer your questions (and bonzoscotts' hopefully).
The plastic timing cover was introduced for the Vortec V6, around mid 96. In the research I've done, it looks like GM had a problem with one of the moulds for the sump/oil pan (they are a cast aluminium sump), and the port lip at the front of the sump was about 40 thou higher than it should have been. That put too much pressure on the bottom edge of the timing cover, and eventually it cracked, and allowed the oil leak we are too familiar with.... It also looks like it was only one mould, and only for the very later 2005 and the 2006 V6s... Looks like QA/QC got to it, but not before quite a few engine went out... It's a problem for both Volvo and Merc and I suspect there are plenty of GM vehicles out there with cracked covers too. The bad news for you Dean, is that the leak will get worst as the crack continues to open up. And because of the location of the crack, filling the area with RTV doesn't work (been there, done that :facepalm:)
The cover can't be replaced by the old steel cover either, the drill patterns are just too different (tried that too) and there is no place for the crank angle sensor for the MPI engines... In 2008 GM changed to an Aluminium cover (gee, I wonder why :rolleyes:) and that can't even be used on the 1997-2007 engines, again because of the drill patterns... (yep, tried that too... Anybody want to buy an unused sump and timing cover for a 2008 V6? :facepalm:)
The only fix I have found it to remove the engine, remove and discard the broken cover and the old sump and put a new cover and a new sump on. The good (?) news is you don't buy the cover and sump from Merc (or Volvo) you buy it from GM and save yourself a pocket-full of money!
Now, the second issue.... This thread was 2 years old, and is considered as archives, our library books if you like. In the Forum Rules is rule #12, that asks not to add to previously 'dormant' threads, like this one, unless you are the original poster..... I'm sorry I have to bring it up, but as we have very active forums we do ask that archive threads be left as that, archive threads. The resurrection of old threads in amongst the new ones can cause a lot of confusion... So we ask, if you have a question that pertains to an archive thread, post a new question, and just add a link to the old thread... (to post a new thread, see the below)...
Cheers and thanks,
Chris....
attachment.php
