V belt sizes???
Bambam24
I have a 1995 wellcraft with a 4.3 mercruiser its the lx. I am trying to find the part number for the v belts one goes to the power stearing and the other goes i belive to the alternator. The engine serial number is 0F299266. If anyone can help i would be greatly appreciatve. It has the normal water pump on the out drive. If that is any help thanks ahead of time.
achris
More fish than mountain goat
Re: V belt sizes???
Take the old belts to the car parts shop and get a good quality belt. Way cheaper than OEM....
tpenfield
Re: V belt sizes???
^^^^ +1 Usually there is a number on the belt that you can cross reference.
However, I often go to http://www.mercruiserparts.com and look up the numbers for various parts, like belts.
On my previous boat, it turned out that the existing alternator belt was about 2 sizes too big . . . no wonder it was at the end of its adjustment range and barely tight.
Once you get the generic number, the automotive stores should have a suitable belt.
wellcraft-classic210
Master Chief Petty Officer
Re: V belt sizes???
All good advice-- if your belts are worn -- and espacially if your pulleys are rusted you old belts will be thinner than when new.
Good argument for matching the oem part number.
achris
Re: V belt sizes???
Your lucky day. The boat with my old engine (1994 4.3LX) came in for service this morning... I put non-genuine belts on it years ago, and they're just fine. So, here are the numbers straight off the belts themselves.
Alternator belt:- 11A1180
Power steering belt:- 11A1335
Chris....
