Using spar varnish
Rsb1970
Thanks for everyone's advice. This is the first boat I've ever owned. I'm not really wanting to restore to factory condition, just get it done enough to take fishing a couple times a month.
ondarvr
Carpet will be put over it and it will be outside but under a tarp.
​This is a death sentence for plywood, spar varnish is of little value in this situation, it takes a great deal of effort to make plywood survive under carpet for a long period of time.
Rsb1970
So basically expoxy is the only way to do it?
Watermann
Also please do not use pressure treated plywood in your aluminum boat. Good quality plywood that is exterior grade if you can't afford or don't want to afford marine ply.
ondarvr
​If you buy a good quality sheet of plywood and don't do anything to it, it should last 5 plus years under carpet, with nothing over it the lifespan will be much longer, maybe 3 to 4 times longer if it's dry when not used. Epoxy will extend the useful life of either method much longer, but if you drill a hole, or don't seal an edge, all bets are off.
