Useful Gas/Oil Mix Ratio SpreadSheet
RLRick
Here is a simple but very useful Excel SpreadSheet that will calculate precise Oil to Gas Mix Ratio's.
Just enter Ratio (example 50:1) and the gallons of gas or ounces of oil needed.
Hope you find it as useful as I have. Many friends are now using it!
  • Gas_Mix_Ratio.xls
RLRick
Re: Useful Gas/Oil Mix Ratio SpreadSheet
My apologies...The new guy messed up.
Apparently I should have saved the thread as a code other than bbcode.
I will try and use HTML code:
  • Gas_Mix_Ratio.xls
No need for a spreadsheet -- since its an Excel document, most people will not be able to open it anyway.. The ratios are printed on the back of the two-stroke oil container.
rosscopeeko
Or you could buy a "ratio rite" mixing bottle made by maxima which has all the info right on the bottle and is clear so you can see how much oil your are going to use for the given ratio. I have a dirtbike also so mixing 2 stroke oil is common and this thing is worth the $8.00 i paid for it.
