Used LU oil
gonefishie
should it smells like sewage? The NAPA brand gear case oil I just drained smells like sewage. No sign of water though. I've always used Quicksilver brand, except last year, and it doesn't smell bad.
Re: Used LU oil
Ayuh,.. Most all EP oils Stink,... Some worse than others...
I use Modil 1, it ain't Tooo bad....
Bob_VT
Re: Used LU oil
Any of the gear oils really smell bad ..... yup like sewage sounds right....... nothing I would use as a cologne :D I have used it as a rust preventative and painted it on truck frames which greatly reduces salt damage. Oil undercoating is very popular here in VT.... but I limit the gear oils to trucks since it smells so bad.
Just a side note..... if you have an ATV and the oil smells like gear oil it is an indicator that you are burning the clutches.
fishrdan
Re: Used LU oil
Hey now.... I once, inadvertently dumped a quart or so on my head/hair trying to wrangle the catch pan out from under my truck. Thinking back,,, my girlfriend wasn't too impressed with my new found odor :rolleyes: or that I combed it back like a greaser trying to lighten up the situation :D
coolguy147
Re: Used LU oil
what oil the differential oil or regular oil like you put in the car? 20wt and such
alumi numb
Re: Used LU oil
i use bar chain oil diluted with diesel then spray it on the underside.
bar chain oil has phosphoric acid in it to help keep the chain from rusting.
Bob_VT
Re: Used LU oil
Yup Bar and Chain is the best....no argument there..... but we just use whatever is on hand ;)
