used boat ..
tabs
what should be exactly considered when buying an used boat ??
tabs ,,
ziggy
Re: used boat ..
google up buying a used boat.... ya'll get many choices to look at...
everything should be considered... the boat, the engine, the drive...
when i was a buyer. no omc products, no mercruser 470 version engines. no odd obsolete drives.
no wood rot in floor or transom
does everything on the boat work, gages, radio, acc. etc. turn everything that does work on and off.
does it reach wot spec for that rig
engine compression
drive lub has no metal in it and is not foamy
pressure test drive
does engine stay cool.... new impeller?
does it shift real nice
does it have a whale tale... if so, why.
is every cleat, snap, rail, screwed on tight pay perticular attn. to anything surface mounted to transom, espesially below the waterline
look the hull over closely, ft. to back, top to bottom, includeing underneath it
test drive is a must, no drive, no buy. does it leak?
i'm sure i missed some... google it....
tashasdaddy
Re: used boat ..
most important: test drive is a must, no drive, no buy. does it leak? make it a 1 hour trip. not just in forward, stop several times, and reverse.
ziggy
Re: used boat ..
ah, go for a 2 hour trip....:D have fun.....
i bought my boat on a consignment sale... i dealt with the owner of the boat store..... he let me check anything and everything, which i did my best to do. among the things we did was a drive pressure test and compression test prior to him taking me out for about 1-2 hours. closer to 2... the dealer was having a great time. i think he drove more than me... wot too, just out of an alleged 15 year storage.... it's like tear it up man.... came back to the shop and retested drive pressure and lub and compression test on the engine..... i had a good experience with my seller... but i didn't take anything he had to say as true w/o checking myself.... it was a one day project to buy the boat.....
tabs
Re: used boat ..
thnx 4 the replies ...
so ,, i must take the boat 4 a test ..
my big problem is that am completely knew !
so ,, i dont know the words used 4 engines or boats ..
i dont even know anything about engines ..
can anyone tell me abt the engines and boats from A-Z ..
well am intended to use a boat mainly for fishing ... might go for a bit cruising ..
any help will be appreciated ...
thanx ,,
tabs ..
tashasdaddy
Re: used boat ..
get someone who knows boats go with you, take a in class safe boating course before buying. you will be better off before buying. you need to know where you are going to be fishing, creek, small lake, river, open bay, inshore or off shore. all this goes into the type boat and power.
read this: http://forums.iboats.com/showthread.php?t=138594
