mattyrich
Thread starter- Joined
- Dec 27, 2008
- 112
Swapping all the components from a 1991 mercruiser 3.0 140 over to an older 1981 mercruiser 140. What am I missing or how do i check to see that everything is getting the voltage they should. I feel like the wiring is perfect, but i have no spark??? I want to check each component of the ignition system, but i didn't get to it yet as i was trying to make sure i had all the wiring correct before i concluded that any one variable was faulty
DOES IT MATTER THAT I HAVE THE MOTOR ON A STAND AND NOT IN THE BOAT... THE WIRE HARNESS IS NOT CONNECTED, JUST A BATTERY TO THE MOTOR???
Before i began this swap, the motor (81') had a distributor with electronic rotor, an automotive coil, a slave solenoid, circuit breaker switch, and the same starter and alt. that are still on there...
I have swapped over the wire harness, valve cover, engine coupler, flywheel housing, fuel pump, and mainly...The Est ignition system (ignition coil, distributor, shift cutout switch(on the Valve cover), slave solenoid. I am still using the starter, alternator, and circuit breaker from the old motor.
Now I'm not getting spark. Any tips?
PLEASE LOOK AT MY PREVIOUS POST FOR PICTURES AS IT DOESN'T SEEM TO BE WORKING RIGHT NOW?
