Updated Manual Link?
Jack2048
Looking for OEM Service Manuals for my Volvo Penta Engine.
Link is broken / empty.
Is there a new place where the manuals are, or were they permanently removed?
After several years of non-use, it won't initialize, ie, start the pumps to prime the fuel system. Was running perfect before. Just running out of wires to check. And would like to narrow it down.
jbcurt00
Copyright violations shuttered most legitimate download sites like boatnfo.
Jack2048
I found my engine and drive manual on ebay. Might look there.
Good idea. Thanks.
I just found the problem. I used the KIS method, "Check all connections" and re-did ground connections. Lots of corrosion. Found another set of ground connected wires, nut was loose.
Donald0039
I ordered manuals from VP website for any that were not downloadable. To do serious work you need to VP manuals. If your VP engine has an ECM you may need a Diacom to read the codes.
