Up or down?
Rford09
This will be my first winter storing my boat, i was wondering if i should store the the boat with the outdrive up or down. The boat will be stored indoors.
Thanks in advance
Rob
tpenfield
Re: Up or down?
down. nothing good can happen with it up.
DBreskin
Re: Up or down?
Down, but not all the way down. You want the driveline to be straight so the bellows is in its relaxed position. The cavitation plate should be parallel to the keel.
Rford09
Re: Up or down?
Ok i am sure i should probably know this, but what is the cavitation plate?
DBreskin
Re: Up or down?
The cavitation plate is the horizontal, flat part of the lower housing just above the propeller. It keeps air from getting sucked down to the propeller when the boat is moving. The proper name is actually anti-cavitation plate.
I guess I should have just said to have the propeller shaft parallel to the keel.
scipper77
Re: Up or down?
I do mine "mostly down" as the ground limits how far down my outdrive goes. If you are storing indoors I'd worry more about mice.
Rford09
Re: Up or down?
Thanks for all the advice. I am concerned about the mice, but i was planning to put moth Balls in the boat, and a perimiter of moth balls and de-con on the floor around the boat. Anything i am missing?
KD4UPL
Re: Up or down?
Store the drive down. This will reduce stress on the bellows.
Barkley, what do you know that no one else does?
scipper77
Re: Up or down?
Barkley was making a viagra type joke. Reread the comment and think about it.
