Re: unknown piece fell while removing out drive
ok, well its staying in there. I replaced my impeller today and when I looked at the water pocket cover, I couldn't believe the melted mess it made. I couldn't remove two of the screws due to the plastic housing melting around it. I had to use a chisel to cut the plastic around it until I finally removed it. then it dawned on me, I only bought the water pocket cover gasket, not the housing :frusty: so now i'm leaving that part un assembled until tomorrow. tomorrow I will get the water pocket housing, and the exhaust elbow gasket. then I should finally be done.
on another note, The impeller was definitely the culprit in my overheating issue. when I removed it, it had no blades left. all were nubs, and they were down below blocking the water inlet vents near the propeller. I cleared those out and installed my new impeller (whoo hoo, 1 thing accomplished). but not before losing one of the washers and having to go to auto zone to buy a new one. while there, I bought new spark plugs too cause mine were burnt out. plus then I can start fixing my starting issue.
so tomorrow I will connect the water ears and give it a spin and hope to god it doesn't over heat again. but first, oil change and gear lube.
