Uneven Tire Wear
DoDbassman
I have a dual axle Ez Loader trailer (2010) and had to replace the front left tire because the inside tread wore out. The outside tread was fine. I noticed the rear tire on the left side was also starting to wear on the inside.
Do you rotate trailer tires or is there a problem with my trailer?
bigdee
Re: Uneven Tire Wear
How are the right side tires? If ok I would rotate. If camber is the issue there is no adjustment short of bending axle.
MH Hawker
If its just one side then its out of alignment and the worst side is the left, so take a close look at the spring eye bushing and the center link bushings.
