Under the deck bilge question
circlehook69
Ok...I have a '94 cobia 156 that I have replaced the stringers and am about to glass new deck in. My question is, can I glass the deck to where it is water tight and not put a drain under the deck? Once I glass the deck in, the only way for water to enter under it would be if I hit something to breach the hull. You're thoughts and comments are appreciated.
Georgesalmon
Re: Under the deck bilge question
I wouldn't. Someway, somehow water ALWAYS finds a way. Best is to make sure water can drain down and to the back where a , drain, bilge pump or sponge can remove it, JMHO
circlehook69
jbcurt00, I am for the main plug through the transom and for the motor mount holes through transom, was just wondering if would hurt anything to glass the deck totally in to make it water tight from the topside. I'm still having the little bilge area with pump for the back of the boat, but if there is no intrusion on the deck anywhere, would I still need the drain for under the deck?
jbcurt00
You absolutely want to do this ^^^
I'll be back, but I'm headed out to a job walk.
circlehook69
Not 100% sure of the flotation yet. I'm undecided as whether to use sheets of styrofoam or just go without.
Woodonglass
Are you talking about the drains for the stringers coming into the bilge?
jigngrub
Only the foolhardy delete the floatation foam from their boat build.
Let me guess, you blame the floatation foam for rotting your below deck structure and not poor ownership maintenance and storage... right?
circlehook69
No I don't blame the foam at all, like you said, poor maintenance and storage from previous owners of hull. The reason I'm considering leaving it out is merely a matter of weight and money. I fish water that is 1-2 feet chasing redfish on the grass flats, not chasing pelagics and bottom fish all over the gulf.
Grub54891
Put the foam back in,someone else may fish deeper than you.....
GT1000000
If you can build the sole basically water tight, then providing drainage is a moot point...
Take my particular build as an example...
I built the sole to be completely watertight and filled as much as I could of the void with flotation foam...
I left a way for water to run freely into the bilge and should therefore never have any water penetrate into my sealed and foam filled sole...short of a catastrophic hull breach from impacting an unseen underwater obstacle...
Any water that makes its way on to the deck, is allowed to flow all the way back to the bilge area where either the bilge pump, or pulling of the drain plug, after a day of fishing, will allow any collected water to drain out...
Basically I created an encapsulated area under the sole/deck, which contains the floatation foam...
For more insight into what I did , check out my links below...
Have fun!
GT1M:D
