Unable to remove propeller on Minn Kota
cgolla
Hi, I have an Endura 55# Minn Kota motor. I believe the shear pin is broken and I removed the bolt to check but I am unable to remove the propeller. It barely moves at all when I pull on it. Any ideas on how to get it off without breaking anything?
Barnacle_Bill
Re: Unable to remove propeller on Minn Kota
The shear pin is most likely bent keeping you from pulling the prop off. Try prying it off and if all else fails cut it off. You are going to need a new prop anyway.
