U joint cross reference, 865493A01
lakeBum85
Is there a cheaper parts store alternative for the 865493A01. I have searched the fourm and did not come up with an alternative to the newer U joints with the external clips. $180 for a set of U joints is a bit expensive
865493a01
lakeBum85
Re: U joint cross reference, 865493A01
Is the $89.09 for one or a set? $89 for the set is not bad but $89 each is a little excessive.
achris
More fish than mountain goat
I believe that's an 'each' price. I hadn't realized they are that $spendy...
Chris...
flipbro
Master Chief Petty Officer
Try an auto parts store and c if they can cross them with something mabe take your old one with you its just a ujoint! I bet even a tractor supply store would have them
lakeBum85
I can?t imagine it being something exotic that only merc's use, I bet it is just a common automotive u joint. I can?t decide for sure if it needs them or not. I get some buzzing vibration during high trim and hard turning but no "slapping" when I turn it all the way either way at idle. Might just be a gimbal bearing I plan on doing a transom service kit before lake season and I will inspect them while the drive is off
achris
Pull the drive and check them... Your noise could also be the gimbal bearing, or even that the engine is out of alignment.
Fun Times
flipbro
theres also alot of good deals on ebay with free shipping in the lower 48 states! Do a search i found them on there for 56 bucks a pair. When the universals went in my jeeps front drive shafts the auto stores were all around 50 60 bucks a peice i got them of ebay 18 a piece same brand as they wanted to sell me hear
lakeBum85
I think I found a set that will work. I wont know for sure until I pull the drive and mic the old set. I read that someone used a napa PUJ 344 but he could not get the clips to seat because the cross was a little long, they spec at 2.940. The Moog Chassis 344's are 2.935 hopfully since they are a little shorter they will work and the price is right at $15.97 each
http://www.summitracing.com/parts/mog-344/overview/
alldodge
Yes and No but mostly no. If the U joints do fit you have an issue with the grease fitting being between two of the joints. The Merc fittings pivot a lot and will come into contact with the fitting. If they did fit and if you removed the grease fitting and plugged the opening, then maybe, but just maybe. The maybe depends on what it was plugged with.
