U-joint bellows clamp, shift cable crimp clamp
natsgrampy
I have an 89 mercruiser 3.0 and need to tighten up the u - Joint clamp at the bell housing. It loosened and is allowing water into boat. I have the outdrive off and trying to remove the bellhousing.
How do I remove the shift cable crimp clamp without destoying the bellows?
All the bellows, shift cable, and hose are brand new and would hate to have to replace them again.
Re: U-joint bellows clamp, shift cable crimp clamp
I have an 89 mercruiser 3.0 and need to tighten up the u - Joint clamp at the bell housing. I have the outdrive off and trying to remove the bellhousing.
How do I remove the shift cable crimp clamp without destoying it?
Ayuh,.... What I would do is,....
Peel the crimp clamp off, 'n Toss it...
Do what ya gotta do, 'n reclamp it with 2 little zip-ties,... 1 each direction...
Or, Better yet is the Mercury outboard fuel line zip-ties, that have a full circle seal nipple cast into 'em.....
Only takes 1...
