U joint and gimbal
scoflaw
Ensign
Big time rumble hard left and hard right. Pulled the drive. U joints are tight and smooth. Gimbal was well greased and turned smoothly. Both are original equipment in a 10 year old salt water boat that sits at a slip 6 months a year. Bellows are original as well, and look fine. No sign of any water penetration. Any ideas?
Re: U joint and gimbal
Ayuh,... You won't see the ridges til you take it apart....
Btw,... 10 Years is an Awfully long time on those Rubber parts....
Nugglet
(or when they decide to really let go & take out the bell :eek: :D)
is there alot of slop in the hinge pins???
