type of wood for floor Mark twain
sa43
I have the stringers out and hull ready for new wood. other than marine plywood (Its not sold in my town) what do I need to buy? Also what is best type of resin? Any help is appreciated.
MTboatguy
What kind of boat? I have use good quality 3/4 in ply in the past as well as 2x4 or cut my own stringers out of 2x6 and sealed everything before installing.
Might want to post this in the restoration section.
great thing about the best DIY restoration forum on the planet
the answers to 95% of the questions you could have are in the stickies
start reading the links in the restoration forum. https://forums.iboats.com/forum/boa...r/295740-how-to-s-and-other-great-information
specifically link 14 and 18
any exterior grade premium plywood would be fine.
BTW, post pics of your project. most likely you didnt grind enough for the new resin and glass (most do not)
Woodonglass
Marine plywood IS the best but...If you use a good quality ext. grade plywood, with Polyester Laminating Resin, CSM, and Biaxial Fabric. and then care and maintain the boat in a responsible manner, She'll last for multiple decades. Factory boats don't have the best quality of laminations but following the advice here on the forum Your's will be Better than Factory. I use plywood for everything, Stringers, Transoms, Motor Mounts Side panels, Seat bases, EVERYTHING.
sa43
sa43
Mark twain. Thanks for info
chevymaher
Exterior grade plywood. polyester resin is what they used originally. Unwaxed. US Composites in florida is the best place to get this stuff.
sa43
I thought this would be quicker lol. I hope i have enough grinding done. This is a lot of work. Harder than I thought. Thanks for the response.
sa43
Thanks. great advice. I didnt know I could use plywood for stringers
when you estimate a project, take the cost and multiply by 3 and the time and multiply by 4 and you then get closer to reality
Woodonglass
When using plywood for stringers you can achieve any length by using 1/2" ply and laminating the pieces together using a 4ft overlap. This drawing shows what I mean...
kcassells
Home depot wood available...AcX, BCX...."A" meaning less voids in fabrication. Never treated lumber.
sa43
I have tried to upload photos no luck. I have read you don't let the stringers touch the hull. Is this true?
I found the a/c plywood at 84 lumber. they suggested I use glue for flooring. Should I? if not what then?
JASinIL2006
You can bed them in thickened resin (aka 'peanut butter') or a construction adhesive like PL Premium. Peanut butter has the advantage of allowing you to work more quickly; as soon as the peanut butter has cured (30 minutes?) you can start tabbing the stringers in with fiberglass. If you use a construction adhesive, you need to wait at least 72 hours (maybe more) to allow the adhesive to cure and give any gasses it needs to. If you try tabbing over construction adhesive too soon, you'll get bubbles in your fiberglass and you'll have to grind them out and try again.
Woodonglass
If you're asking what glue to laminate them together to make em long enuf then Titebond III is the best glue to use.
